01.18.2009, 03:01 PM
In the past I have used a cigarette lighter. If you hold the flame over the varnish within a few seconds you can see the wire getting discoloured and you will find that the discoloured wired has lost it's coating and will solder or conduct current. With a bit of practice you can only heat up the segment required.
Mohan
