year1camaro
year1camaro's Avatar
01.18.2009, 10:50 PM
[QUOTE=ssspconcepts;253388]Brushless OFNA DM-1 SPEC: Flightpower 5S 5000mah (25C) Battery, Mamba Monster Speed Controller, Neu/Castle 1515 2200kv motor, 51T Mod1 Spur gear, 25T Mod1 pinion (I know this is too big...but its fast as heck and fun), and Spider Eight 43/13 ring and pinion differentials.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 25
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 4.17
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.04 : 1
Total Ratio: 6.74769 : 1
Tire Circumference (inches): 13.1 inches (332.75 mm)
Total Motor Speed: 40700 RPM
Vehicle Speed: 74.83 mph (120.2 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
As promised here is my amature video...
What tires did you use for this run? Car looks fast fast fast!!! nice...Now to get it to stick to the road might be a challenge with all that power.
