ssspconcepts
ssspconcepts's Avatar
01.18.2009, 11:25 PM
That's pretty sweet man! Very clean install, too. I might have to copy you...
Thanks...I wasn't too happy with the way I ran the receiver plug wire from the MMM to the RX. I had to run it under the motor. It is fine...as it doesn't touch anything and its out of the way from moving parts and there was plenty of space under the motor...it just looks funny. I tinkered around with running the ESC wire over and around the center diff mount and that was worse-so this is what I ended up with.
