ssspconcepts
ssspconcepts's Avatar
01.19.2009, 10:15 PM
Originally Posted by BlackedOutREVO View Post
What/who makes that spool?
And any tips on building this puppy up? My buddy is building one currently, and wants a speed machine, CC combo, 220 KV, 5s, and a zippy 4000 mah batt
If you want a single speed center, then you will need these parts. You can either buy them separately or use parts from the stock 2-speed to build the center:
http://www.nitrohouse.com/catalog/pr...ducts_id=12086
http://www.nitrohouse.com/catalog/pr...ducts_id=11306
http://www.nitrohouse.com/catalog/pr...ducts_id=11016 (you can ditch the shaft that comes with the silver aluminum spur mount)
http://www.nitrohouse.com/catalog/pr...ducts_id=10760
http://www.nitrohouse.com/catalog/pr...ducts_id=12091
You will also need a 13mm long piece of 8.1mm inner diameter steel tubing and a couple of 8mm steel washers because the 8mm center drive shaft does not have bearing stops milled on it to prevent the shaft from sliding back and forth.
BTW...this thing is nuts on 5S. I had a hard time keeping the tires from spinning with my 5S/2200kv. I couldn't imagine 6S.
