Ryu James
Ryu James's Avatar
01.20.2009, 08:39 AM
yeah, that sucks bro. frustrating huh. you can cut into the endbell but i wouldnt. i did this and once you start it never stops and your motor looks like crap. plus you usually have to cut away way more than you had anticipated. i would get a another piece of 3mm alum or carbon and make the spacer thicker......or buy a tekno conversion kit.....at least that is what i would do next time if you plan to run mechanical brakes. Mike sells the kits on his site or you can get them from impaktrc.com. good luck.
Jammin SCRT10 Neu 1512 1y
