01.20.2009, 11:58 AM
IMO not worth the trouble unless you happen to have the motors laying around. Not only do you to do this on setup, but anytime a you change the spur and if a pinion grub screw comes loose - pretty much anytime the mesh changes at all.
Is it possible? Yes.
It is practical? Not really.
Better off getting a single motor setup that is the right size. Setup and wiring is much simpler.
