Countryhick
01.20.2009, 04:30 PM
Originally Posted by Ramaciotti View Post
Good afternoon!
What do you guys think about to use a NoVak 4.5HV (with 4s) and what's the best gearing to run near to 140km/h?
Thanks again!
Aldo
What gears do you plan on using? eg. original serpent or modifying something else to fit.
To achieve the kinds of speed you are talking about with the Novak 4.5 I think you might run into some over heating issues if you plan on running continuously on the track.
Are you planning on using mechanical or motor braking?
1/8 onroad cars are a great build to do. You will turn a lot of heads when you are finished.
Keep the ideas flowing there are a heap of guys on this forum with a wealth of knowledge.
Cheers Andrew
