Originally Posted by dangerwr
Thanks so much for shipping SST tubing for the center drive. I am so psyched to get this thing on the road. I still have a little way to go but have time because if there is not snow in the parking lots it is wet from melting. I found a company http://www.extremercracing.com that makes a graphite servo tray that might fit once modified--they are much easier to modify with a dremel. Did you tap screw holes in the RC-Monster battery tray?
Yes I did use a tap...but you really don't need it. Just mark existing screw holes from the chassis onto the battery tray and drill them one size smaller than the screws you intend to use. Then just use the screws to tap your holes into the battery tray...
I didn't use a tap for the Ultra build and it actually worked out better...
