George16
Supermaxx
George16's Avatar
01.21.2009, 05:15 AM
Originally Posted by Rivermaxx View Post
Thanks guys Btw will a g2 chassis work with a UE mono block?
Only if you use the G1 rear end or cut the G2 rear end. I have a G1 rear end with mono. The driveshaft you'll need is 110mm. You can buy the titanium 110mm shafts from UE.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
