01.21.2009, 08:52 AM
Whats the diffrence beteween the two. I thought it was only the lower chassis plate was different. I also thought the g3 cassis had the different upper plate that required you to use the front flattened out skid in the rear which wouldnt work with a mono. Question is, should I use a mono block or buy a g3 upper plate and use a front skid which would be cheaper stronger and better over all to lengthen the wheel base a little. Lets see mono is $65 upper plate is ~ $25 and a rear aluminum skid is $19 and a used titanium one is $25 so ~ $50 compared to about $90 for mono with ti skid. Mono would be stronger for sure and I could use any normal ti skid. Descisions decisions.LOL
