01.21.2009, 08:58 PM
The front uses the same length dogbone for the e/t maxxes; 57.5mm. There's a bit of play so you'll need to put one o-ring for each cup. 59mm would be the ideal length if you decide to have one made by RCalloy.
I can't see the picture from work.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
