What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.21.2009, 10:05 PM
If you're gonna drill and tap threads edge-wise into material, I would go with at least ~6mm thick (~1/4") because you'll want to use 4mm screws I would imagine...
I havent had a problem drilling and tapping 1/8th" aluminum
What size screws are you using? 2-56? Edgewise would be into the 1/8 thick side..... But yeah with 3/16 that could be a problem. 4mm screws would be too big, but if you used 4, 3mm screws in the bottom (instead of 2, 4mm screws) that would do it. Or try and get 1/4 thick material and use 4, 4mm screws!
