01.22.2009, 02:35 AM
James, did you cut the foams?
I took about 1/4 off the width of the foam, seemed like a bit too thick for the tires once they were on narrow wheels (proline 8 shooters). I guess if you ran the tir on a std width 2.2 truck rim the foam would be fine. I did not star cut the foams, as they seemed soft enough after narrowing. They work great, best crawler tires I have tired. I have used moabs, mashers, lizards, hammers, flat irons, and claws and these are better than those...
