01.22.2009, 03:42 PM
I have an Mbx5 buggy converted with 36 60 medusa ,mmm same gearing and runs 40ish on 4s and is almost cold to touch after running for 10 mins.I have run the same 5s pack in that one too and it did get a little warm,but not that hot like the mmm combo did, different wheels and tires though,and of coarse,lighter.I need some more mod1 gears to try gearing up or down,kinda seems like it could be geared up with everythingelse being so cool and all,but I'll try both ways. I reset the timing to low and will give that a shot today and will try all that was suggested .If it continues to run hot,I might have to pull it and try a 70 or 80 can medusa,they seem to run very cool and strong.And yes the 2200 runs very well indeed,with the front end pulling up anytime you want to, real torque monster.I did do the diffs at 7k 10k 3k,not so sure this is right for a truggy with this kind of power,but turns and burns well enough,with the front unloading a little when you put full power to it.
