Thread: Revo Mod 1 Spur
01.22.2009, 08:07 PM
Originally Posted by ssspconcepts View Post
Do you have any pics of the installation/mod? Thanks.
Open up the center hole slightly so a 5x10mm bearing will fit in it. The revo uses a 5x11mm bearing stock. Then just drill out 3 of the smaller holes to 5mm so that the posts on the slipper can pass thru and reuse the existing bolts that hold the spur on. I will try to get some pics of a modded mgt spur next to stock mgt spur. Really easy, you can enlarge the center and side holes with a body reamer if necessary, as long as the center hole is concentric the spur will run true.
