Originally Posted by lincpimp
9lb truggy
Stick with a neu for those truggy size wheels and tires. You need torque to make the heavier wheels/tires react quickly. If you plan to make it super light, a 1512 or medusa 60mm on 6s should do the trick. Something like 3000mah 25-30c cells for power.
Dont know how you plan to get the truck under 9lbs.... Everywhere I have looked has the kit weighed as 9.5lbs without electronics.
