This should clear things up.
GREYGHOST
This should clear things up. - 01.23.2009, 03:19 PM
Calculating the viscosity of a blended liquid consisting of two or more liquids having different viscosities is a three step procedure. The first step involves calculation of the Viscosity Blending Index (VBI) of each component of the blend using the following equation (known as a Refutas equation):
(1) VBI = 14.534 × ln[ln(v + 0.8)] + 10.975
where v is the viscosity in centistokes and ln is the natural logarithm (Loge).
The second step involves using this blending equation:
(2) VBI-blend = [wA × VBIA] + [wB × VBIB] + ... + [wX × VBIX]
where w is the weight fraction (i.e., % ÷ 100) of each component of the blend. In using the above blending equation, it is necessary that all viscosities are determined at the same temperature, for example, 100 °C.
The third and final step is to determine the viscosity of the blend by using the invert of equation (1):
(3) v = (ee(VBI - 10.975) ÷ 14.534) − 0.8
