plettenbergs
plettenbergs's Avatar
01.24.2009, 09:23 AM
i would say that the plastic spur is my only week link...but,i did get 5 10s runs out of the last one,i will go up a tooth or two
hey Jerry:2 mono's sounds funky,seems like it might be kind of flimsy where the two connect??but for straight away top speed runs it should be fine
my Dual BL was a little top heavy so i will need to adjust the shocks a little...they are polished UE supershocks with PROGRESSIVE piggy backs...now i am running 4 UE chrome springs and 4 black springs,i might swithch the blacks to reds...that should lower it a bit?...i am also going to try two 19 or 2 20 tooth pinion gears...that will also will help with the wheeelie factor
OK i have a lrge cup of coffee and will try to get the video up again...my original video was much longer and i will try to get the rest of it up also
