monsterbaja
monsterbaja's Avatar
01.24.2009, 02:37 PM
The problem lies her.
This motor is only 50mm wide.(it is only 10 mm from the diff.)
But you can consider a Lehner 3060.that is a wild motor,and it will tear you baja apart. It is 60 mm wide and 100 mm long.
But i also think that the neu 2215 770kv will be more than enough to tear the car apart.
