01.24.2009, 03:44 PM
Ran my Mbx5 buggy and truggy just to compare them with the two different setups.The buggy is a 36-60 on 4s and it kills the truggy in speed and handling with the truggy running on 5s 2200 combo.Heck the buggy has 7k-50k-3k setup for fluids and runs the same gearing except for the tire size factor.I'm going to put a 70 can medusa in the truggy without changing anything else just to satisfy my suspicion about this 2200.Pretty much tried everything else.Put a 12 tooth pinion on there and made it nice and quick...and slow on the top end,but actually got hotter,up to 178.Settings on the throttle curve are like Mikes and it really mellows it out till you pull the trigger harder.I did the curve to my buggy and it really makes a difference in driveability.You can adjust you radio settings also to get similar results.Put some 30k in the center last night and will run it again with the 14 tooth to check the unloading situation.Putting all new drive axels and cvd's in cause they are a little bit warped.
