Thread: BL Tc3
CrazyPhantom
11.29.2005, 01:18 AM
Yeah, If you think the chassis looks good in a picture, you should see it in real life. This is only the mock up chassis to beleive it or not. I need to change a few things here and there, and then have Andrew over at Cold Fusion Racing cut me another one. I decided that I am going to try to run dual lipoly packs. Now I have to find a pack that will fit with out me having to rearrange the steering setup on the car. I think Im going to get the poly-quest 3100N 7.4V batteries, becasue they are the closet thing I can find to fitting and still near the mAH's I'm looking for. The motor will be mounted above the spur gear, trying to keep it as low as possible still. Well, I gtg to bed, so more updates will be up tomarro if I have any (Final chassis design will most likely be done tomarrow)
Thanks
-Joe
