01.26.2009, 10:58 AM
Right now the V3 failure rate looks to be much lower than MGM and significantly lower than Quark. The V3 has remained pretty stout. With the type setups being run with the MMM you're bound to see one go now and then. I only know of 3 of the 3000+ that have been sent out. Even if the failure rate was ten times that it would still only be 1%.
