01.26.2009, 11:51 AM
Update! The cen lockers finally came - They were too big for the CRT .5 diff! :(
The rear diff looked a little messed up anyway so I ended up using epoxy instead. Whilst I was at it I replaced the tiny CRT.5 outdrives with 1/8th scale version from an X1X - This meant I now need 104mm ish dogbones.
I ordered a couple of these last night from a ebay chop shop - Hyper centre's are 106mm and should work...
On the centre diff I used the trusty dremmel to cut about 3mm off of length of the locker - It then slid perfectly into the centre diff.
So I'm all locked and loaded waiting impatiently for the bones as the snow melts :)
