Pdelcast
Pdelcast's Avatar
01.26.2009, 11:55 AM
Originally Posted by TexasSP View Post
Right now the V3 failure rate looks to be much lower than MGM and significantly lower than Quark. The V3 has remained pretty stout. With the type setups being run with the MMM you're bound to see one go now and then. I only know of 3 of the 3000+ that have been sent out. Even if the failure rate was ten times that it would still only be 1%.
Over 10,000 now if you include OEM versions. Failure rates are significantly below 1% (about .2%), which is really amazing when you consider that these are very high power devices.
Patrick del Castillo
President, Principle Engineer
