Originally Posted by mikey09120
honestly, a VXL does not have enough power to push a slayer. a medusa 70mm 2000kv with a MMM on 4s-6s is the cheapest setup and has awesome temps and power, you get what you pay for. i would also not recommend purchasing maxamp as many believe they are overated and data supports this. try a couple 30c flightmax zippys http://www.hobbycity.com/hobbycity/s...1&ParentCat=85
also. do you have a conversion kit?
idk about motor brakes with two speed. but locking into 2nd is the best option. why do you want two speed?
I have had real good luck with maxamps so far plus they are only 20 minutes from my house and if you pick up the lipo directly from them you get 25% off. I want to try the vxl first if it sucks I will upgrade.
