Serum
Serum's Avatar
11.29.2005, 05:34 PM
I would personally don't use this setup. invest a few bucks more, than you are on the 100% save side.. you are hitting a 40000 rpms with that setup, the motor will draw some amps if he has got some resistance on that rpm's.. A kv of 800 would be better if you want to use that controller. but again.. invest a bit more, and then you have got the real deal.. :p
You will have got some nice runtime at these high voltages!
