01.28.2009, 05:05 PM
Originally Posted by qcstrokr View Post
I just pick up a igt2 yesterday and wanted to go electric with it. Can anyone point me in the right direction with this as far as what motor mounts and motor and esc to use?
Thanks
The rcm kyosho mount should work... As far as getting 40-90mph... You will most likely need a 2 speed (IIRC the igt2 has one) to get 90mph. You could run a mamba monster 2200kv setup on 4s and stick with 1st gear only for 40mph, then run the 2 speed with 6s lipo for speed runs. You would ne 2 lipos to do this though. Best way I can think to do it with one motor.
