Electric Eel
01.29.2009, 07:34 PM
I'll put some up tomorrow night. Is there anything special you would like to see?
A few more details, the battery boxes are nice! The accessories bag has foam blocks and foam strips to customize the internal size. Box size is 30.4mm x 51.1mm x 201mm. (Rough measurement with calipers).
The outdrive dogbones are the new XL large head style. The front and rear bones are the same smaller size as the X.
The ESC mount is held up by the frame on one side and a thick hollow plastic standoff on the other (next to the motor).
The radio box has a lot of room with no throttle/brake servo or reverse servo. I took out the AM RX and put in a Futaba 2.4GHz system.
The center of gravity is impressive. The motor sits low and the balance is much better than the standard nitro X.
Of course, the real test will be how it holds up after numerous backflips and wheelies! HeHeHeH.
