crazyjr
crazyjr's Avatar
01.30.2009, 05:55 AM
No problems with steering at all. Then again, I'm also using a Hitec 5955TG servo for steering. You can raise the front diff oil to 7K if you want to. Use them as your baseline and go from there.
I was meaning i had no problems with steering, with the thick fluid. I am currently running a cirrus 70 servo (about 250in.oz at 6v)
