Thread: LSTeeee
01.31.2009, 12:53 AM
Originally Posted by TwzteD View Post
yes sir, q: do i need to use flux when soldering with silver solder?
What are you soldering? Flux is usually a good idea as it cleans the wire, and helps the solder flow and stick. If you are soldering al, zinc solder with the appropriate flux is a must, as lead solder just does not work well.
