Originally Posted by hemiblas
My emaxx 3905 geared for 38mph is about 35A continuous and 78A peak. I know the more efficient motors peak higher. If you are looking for a little extra the SPC 8000mah pack is rated for 100A continiuos and around the same price. I have run the truerc packs and SPC packs on this setup and they hold their voltage and never get hot. In general though its good advice to get higher C rating, but it depends on the manufacture. Not all of them are as trustworthy as others. I have had 20C 5000mah packs that dont even come close to the truerc and spc packs rated at 10 and 12C.
Thanks for the great answer, what motor are you running?
just wished there was a 14,8volt 8a pack with like 12 or 15c...
I will be very happy if someone can put some more info on this to me.
Thanks a lot again
