02.02.2009, 08:35 PM
OK, I'll give that a shot. I've got the diff apart again right now so it won't be as much work. I plan to remove the front input cup and shim the pinion, it needs a shim (there is a little bit of the pinion not making contact with the ring). The cup is still on pretty tight well though, despite the screw being out.
