Shark413
Shark413's Avatar
02.04.2009, 01:51 PM
Originally Posted by auto2 View Post
if i may what is the difference between the 1 and losi 2? the chassis...center drive shaft is longer.... what else? also will a body form the 1 fit a 2?
Front A-Arms and carriers are different, rear a-arm and carriers are different, the rear outer hinge pin is larger (3.5mm), the front and rear shock towers are different (lighter), there are grease shields on the center cvd's, aluminum parts are anodized black, different rear diff housing, different radio tray (stronger), body has a slightly different design, but will fit on 1.0 version. Steering parts are different. Mainly small updates to fix issues with the first version and to add some better handling and more durability, nothing major.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
