manulesurfeur
02.06.2009, 03:37 AM
Thank you guys!
Yes, it is the stock slipper.
For the moment, i will use 14 cells nimh.
Ok for the calculator.
I understand a little more seing your values!!! I was not in the good section in the calculator... Sorry...
One thing, how we can know if the motor will not warm?
For the slipper, i will maybe take the RRP. I dont know...
I will use moab XL tire for the moment.
Here is what i get :
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.7222222222222223
Additional Ratio: 1
Spur Tooth Count: 66
Pinion Tooth Count: 21.078
Battery Voltage: 16.8
Motor KV: 2200
Tire Diameter (inches): 7.3
Top Speed (MPH): 45
I think I will take 66t spur gear and 22 - 24 - 26 pignon
What do do think of this choice?
