Originally Posted by blueb8llz
what up hoov. so just recently i took the time to try out all the diff. set of tires you sent me. and your right, those foamies are a blast to run with....its sorta like a drifter hahah.
but for some strange reason, still no wheelies. i thought for sure once i put them smaller tires back on, it would wheelie. are you sure theres no slipper for the rc18mt? cus when i gun it from the start, itll slip 1-2 feet, then itll take off. i managed to hit 40mph on it the other day on a big open area. normally i would top out at 37mph...using stock tires.
so now im thinking its the 3s lipo....they are totally off balanced now. all three of them.
it would show something like 3.92 4.15 4.22
even after fully charging, the numbers are waaay off haha.
i think those zippys are done with. plenty of speed left, but no initial punch.
i was thinking of getting them zippys again since their cheap, but maybe a 25c instead?
You need to balance the batteries before you charge them if they are that far off. Then charge them back up at a low rate, like0.1ampd and let them balance during the charge. What brand are they, and what balancer are you using?
