02.06.2009, 02:43 PM
Originally Posted by blueb8llz View Post
ouuu reallly. you can balance them without charging? how do you do that? im using a hyperion 0606i charger with the hyperion jst-xh balancer.
i always balanced and charged at the same time. im using the zippy 20c lipos.
i dont think the charger can adjust the charge amp rate. i can just adjust the number of cells and the total mah on the lipo, unless i dont know how...
I do not think the 606i will allow stand alone balancing. I have one and will have to read the manual. You can just set the charger to 100mah, or as low as it will go and it will charge and .10 amp. It will only put in 100mah worth of charge, but it will give the balancer time to do its thing and get the higher voltage cells drained. I used to do this with my 5i chargers, even though I used an external balancer. This way you will get some charge in the lower voltage cells while balancing. I guess an external balancer is still a good idea, huh! Glad I still have a few. I know the 610i chrgers wil alllow stand alone balancing, I did that with my new one last week.
