Originally Posted by hemiblas
I guess thats why its worked for me. Just dont go over 10-15 minutes of run time, keep it geared conservative and mostly on road use. The torque is just crazy. I'm with blue on the torque. Any more and my emaxx would probably fall apart and my stock tires would explode, but it keeps on running. I can see where they would not be good for a race and thats probably why everyone is against them. I'd still throw the 7XL against any nitro and come out ahead any day of the week.
Yeah, when I had my converted Revo, a Feigao worked well for me too since I was using 14XGP3300 cells and got around 14-15 minutes of runtime. Just enough to have fun before the cells dumped and gave it enough of a break for proper cool down.
I know Brian G is against the fans, but I just realized your in Iowa. Even a feigao wont heat up out there in the cold. Out here in Vegas when you start your run at 110 degrees the fan will keep temps under 170. Between May and August I just dont have a choice.
LOL, ya know, it
does get hot and humid here in the summer too. 90-100*F days are not uncommon in the summer. Even then I never used a fan. Truthfully, if you need a fan, just get a bigger motor with a similar kv. Power drain will be the same but the added surface area helps a lot.
