Thread: MMM V3 dead? :(
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
02.07.2009, 10:36 AM
If it happened right when you drove over your mate's Rusty, then it sounds like it might just be the ESC switch. They're a little delicate, and that kind of bump might have damaged it. Try removing the switch and just soldering the two wires together. If it still doesn't work then it might be something more sinister, but it's definitely worth making sure it's not the switch first.
Dead MMMs usually won't connect to the CastleLink, so I'm betting it's just the switch or a dodgy soldering joint on your batt connectors.
