02.08.2009, 07:06 PM
Originally Posted by e-mike View Post
normal to see this temp difference....8400mah(me too i tink that the maxamp are 20-25c)vs 5000mah 25c
so even at 25c the maxamps give 200amps and the neu give 125 amps contiously....
125 amps is a bit close IMO to what the xl can pull under load. I think the 6000 enerland cells would be a better choice for 4s useage in a heavier truck. My trakpower lipos in the erevo with a 1515 1.5d were about on the edge performance wise, but that truck was geared for 50mph.
4s setups in Mt are really not such a great idea. 5-6s works much better and open up battery choice quite a bit. Plus the lower kv (1500-1600) motors do run cooler with the same over gearing than 4s does.
