Serum
Serum's Avatar
03.05.2005, 04:13 AM
Normally the UBEC can handle a voltagedrop, it has got his own voltage regulating/correcting circuit.
Okay, what i would like to know;
1-did you try a normal 6V batterypack (rechargable!)
2-what thickness of wires are you using between the bat/esc?
3-what plugs are you using between bat/esc?
4-have you got a few pics of your setup as installed?
you are running your truck on 7 cells only? This could be the problem; the setup is able to pull like 100A+ The voltage would drop till .8 volts. this is 5.6 volts. very critical..
