A4DTM
12.02.2005, 04:38 AM
so, I made one small mistake on the rear diffcase dimensions, and as a result, I have to design a small plate to make the rear brace attach to the diff..
Also, I'm not sure if I had used the wrong size for the Sub-C cells, but only 7cells will fit sxs flat per side.. 18 will fit total, if you build two 9cell hump packs.
[btw, the lower chassis is 1/16", while the final piece will be out of 1/4"]
I tried to get decent pictures of how some of the parts "lock" together.. my camera's flash hates me :(
Hopefully I'll have everything straightened out and Andrew will be able to start cutting final pieces sometime next week.
