Sower
Sower's Avatar
02.10.2009, 10:21 AM
I don't know if the springs will fit - you should be able to check the diameter of each shock set to check. Typically Tower Hobbies will give those specs when you look up the part.
I will say that if you plan on racing or getting more serious, the big bore upgrade is one of the best things you can do. Made 100% difference when I did it to my XT8 truggy. No comparison.
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
