02.11.2009, 03:30 AM
Originally Posted by drkdgglr View Post
Thats not the only difference. Muggy shock shafts are shorter than LST2 shafts, and therefore overall length and shock travel are also shorter.
That's what I was hoping for. The LST2 shocks are about 10-15mm too long. But everything else is perfect.
If they are the same as the LST2 shocks, then they are not Muggy shocks. They are probably aftershock shocks. Do they match the dimensions I gave? My dimensions were dead on hole center to hole center. If you got them from a chop house on ebay, I would say they made an error. I had that happen to me when buying Muggy diffs one time, got aftershock diff (wrong ratio, but looks the same).
Yeah, they must have made a mistake then because they were the exact same length as the LST2 ones I have. The description specifically said Muggy, not LST or Aftershock. Crap. Anyone want to trade a couple brand new LST2 stock shocks for true Muggy shocks? And if the Muggy shock bore is aluminum, I have a couple of aluminum LST2 shocks I could trade instead.
