drkdgglr
02.11.2009, 03:33 AM
And if the Muggy shock bore is aluminum, I have a couple of aluminum LST2 shocks I could trade instead.
The Muggy shock bore is plastic, but is the same size as the LST2's shock bore. You could also just replace the shock shafts of the LST2 shocks with Muggy shock shafts. Then you'll have aluminium Muggy shocks.
edit: http://www.losipartshouse.com/servle...ln--MUG/Detail
