02.11.2009, 10:45 AM
Given similar design, motor weight is often a good indication of power output. The castle motor is larger in diameter, and has a finned can. Both add weight. IIRC the ccneu has a larger diameter magnet assy, so that will be heavier and produce more torque. I would be interested to see the magnet assemblies compared, but how do you get the endbell off a medusa?
