Thread: HFX / BrimStone
BitHed
02.11.2009, 08:55 PM
...I love this truck...The HFX is up and running...I am really happy with it...I dont know if its running more like a Savage or a Hellfire...
...it jumps VERY flat and straight and controllable...Shocks could go a tiny little bit harder...Diffs are X factory grease and diff action is pretty much spot on right now...The HF center functions flawlessly and powerfully...Medusa 3560-2200 is spot on and is staying cool, though admittedly i will have to start to play with the gearing soon...its ESavage 66 spur on a HF center diff...
...Batteries are reasonably far forward and the front stays down though that COULD be due to crappy batteries...But even at full charge it just squatted briefly and then popped back up four on the floor...
...The function of the wing is debatable and it might come off for the weight factor...Looks so cool though...
...I traction rolled it once on pavement last night, well actually at 1am this morning, but it seems to prefer to pop up on three wheels and haul itself around a corner...Will have to change the rear a little bit so it slides a bit more...
..its 4.6kg RTR with 12 nimh and Warlock rims...Will change to kyosho 10 spoke after the next pay day...Tires are TBC but will PROBABLY stay with dirtbonz...need to check the weights today...
...mate if EVER there was a need for lipo its now :D I will sell off a whole bunch of stuff and invest in some...Again, advise will be needed...
...I reckon i can get it down to 4kg, or maybe even a hair UNDER with lipo and kyoshos...Body is TBC because I want to see what length Generis shows up with first...Not having the stock body mounts mean i am VERY on the edge of not having a body that will fit...I wanted to fit the stock (shape) Savage body but wiring could be an issue under the rear bed...
...Still looking forward to trying it with the esav center and jedi mount...Still VERY anxious to keep the motor in midship as opposed to off to one side...
...I am thinking the Aggressors might be a better choice on lipo than the dirtbonz...hmm...glad i had that thought...
...imagine that...A 4kg Savage :D
RE: the rear uprights...Atomic does some in gunmetal that are quite square...They look ok and are similar in price depending on where you get them from...
...I can get the 'parts' seperately from the upgrade kit...I might fit the upright braces that lower the upper arm...If anybody would 'like' parts from the set LMK and I will look into it...
