Shark413
Shark413's Avatar
02.12.2009, 02:39 AM
Originally Posted by himalaya View Post
Does Losi have 48T or 49T plastic spurs? My Tekno Losi 8-T's motor mount is too far away from center diff to allow spur smaller than 48T.
Plastic spur must be much quieter than steel, makes the truggy feel even more "electric". I love that style.
himalaya, because they had to swap the diff around on the chassis and there is no cutout on the chassis in the new position the largest spur you can run with the Losi conversion is 45T. Losi currently makes three plastic spurs 45, 44 and 43 teeth. You can use thicker spacers to raise the diff for more clearence or you can cut a hole in the chassis, but that has it's own problems, higher CG, more angle on the driveshafts, weaker chassis (with another cutout), etc. I am running the 45T spur and a 13T pinion it is very fast, has good acceleration, and is running cool so far (a few street runs only).
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
