02.12.2009, 03:30 PM
Can you take some shots of the dd unit from the side so that i can see how the gears are attached to the shaft... They look like pinion gears with set screws. I am guessing the top shaft is a savage input shaft, and the bottom shaft looks to be custom made.
The al is cut with a water jet by the looks of it, and the fact those holes are not drilled correctly makes the hole unit crap. I would send it back to Dan and request your money back.
If the lower pinion is the same as the over size plastic pinions he sells for the emaxx (which come from sdp-si) it will not last. I stipped a few of those pinions in a bl revo conversion, with a 9l on 3s lipo geared for about 35mph.
The whole thing is cheap, and poorly made too. I will definately say that the 4 parts needed to convert a nitro savvy tranny into the flux tranny are a much better bet.
And those battery trays...wow.
