Differences
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Differences - 02.12.2009, 07:01 PM
With the center diff setup the only adjstment you have is changing your fluid in the diff. With the slipperential you can actually make adjustments to your slipper for better control if you wish right at the track or while you are bashing. And yes as Neil said it sure does look SEXY
SUPERMAXX YOUR LIFE.
