alangsam
02.12.2009, 07:28 PM
With the center diff setup the only adjstment you have is changing your fluid in the diff. With the slipperential you can actually make adjustments to your slipper for better control if you wish right at the track or while you are bashing. And yes as Neil said it sure does look SEXY
is the slipperential going to work in the 3905 emaxx and e-revo?
